소개
This guide will show you how to remove the optical disc drive from the motherboard on the Xbox One S. When taking apart the disc drive, make sure to gently and firmly detach the connectors.
부품
지정된 부품이 없습니다.
Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Important!!
You've to start from the back corner where is the information label, because there is a main clip behind a warranty sticker
They should add this to the guide! I didnt know that, and did some minor damage to the bottom piece where that main clip is.
I dont mind because it's my own Xbox, but what if it belonged to a customer?
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
Do not remove the back panel from the metal housing by popping loose the “rivets” in Step 5 photo. Those are not rivets, they are melted post-end mounts in which the heads will break off and CAN NOT BE REPLACED by the do-it-yourself repairer (unless you want to try hot gluing the mounts back to the panel, but success is uncertain with this method). While doing my own tear-down following the photo examples, I thought the rear panel was meant to come off due to the photo of it laying next to the body in Step 7. This is inaccurate, and will most likely result in a loose fitting panel upon reassembly. The “rivets” no longer have a means to hold onto the metal body tray they came loose from. So you will have the panel relying on alignment back to the channel the tabs came out of in order to hold it to the back of your machine. Other than this issue, I was able to perform the tear-down without problem.
Gently separate the interior case from the white exterior case using the appropriate method.
To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
Some of my silver were gold screws, so just letting people know to look out for that!
Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
Do not disconnect the connector in the second image! There are tiny prongs that bend easily and if bent just a tad bit they will break off. I had first hand experience with this and I ended up breaking my Xbox because I could not put that cable back on.
Do not remove the cable!!!! You can change while the cables are plugged. It took 2 hours trying to put mm precisely all the little pins because of the removal of the cables.
Please update the post, I could easily end up as the Aaron, breaking the XBOX completly.
To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
다른 15명이 해당 안내서를 완성하였습니다.
댓글 2개
alles schwachsinn: habe an meiner xbox one s dfas optische Laufwerk ausgetauscht ,da beim alten die spiele immer einfrohren .Alles nach Anleitung wie hier beschrieben . nun geht Garnichts mehr , kein bild kein ton geschweige noch ein spiel neu zu installiren .
