주요 콘텐츠로 건너뛰기
Xbox One Stereo Headset Circuit Board Replacement
필요한 것
  1. Xbox One Stereo Headset Circuit Board Replacement, Adapter Circuit Board: 1 단계, 이미지 2개 중 1개 Xbox One Stereo Headset Circuit Board Replacement, Adapter Circuit Board: 1 단계, 이미지 2개 중 2개
    • Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
    • Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
    • Do the same to the other side until the casing comes off.
    • When reassembling, first align the headphone jack in the back of the adapter body with the hole in the casing, then align the tabs on the floor of the casing with the holes in the bottom of the adapter body.
  2. Xbox One Stereo Headset Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove three 5.0 mm T5 Security Torx screws along the edges of the controller housing.
    • Remove two 8.0 mm T5 Security Torx screws near the top-center of the adapter.
  3. Xbox One Stereo Headset Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • With your fingers, carefully lift the adapter housing from the button panel.
    • Be careful not to yank the wires connecting the two halves of the circuit board.
  4. Xbox One Stereo Headset Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Pull back on the controller USB connector with your interview to separate the main adapter circuit board from the rubber mold in the button panel.
  5. Xbox One Stereo Headset Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 5.5 mm Phillips #00 screws connecting the smaller circuit board to the adapter housing. The smaller circuit board should come right off.
    • One of the screws is located beneath the connecting wires, so you may have to move the main circuit board around until you can see the screw.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Justin Rosescu
회원 가입일: 01/30/15
500 평판
안내서 2개를 작성함
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G37
4 회원들
안내서 5개를 작성함
2가이드 댓글
Where do i get the circuit board to buy ?
Ramesh Sirdar - 답글
Thank you, I opened the adapter in minutes, which is all I wanted to do.
Laurschanny - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 7,659
