주요 콘텐츠로 건너뛰기
Xbox One Stereo Headset Foam Ear Pads Replacement
필요한 것
  1. Xbox One Stereo Headset Foam Ear Pads Replacement, Foam Ear Pads: 1 단계, 이미지 1/2 Xbox One Stereo Headset Foam Ear Pads Replacement, Foam Ear Pads: 1 단계, 이미지 2/2
    • Insert the metal spudger between the foam ear pad and the black plastic speaker cover.
  2. Xbox One Stereo Headset Foam Ear Pads Replacement: 2 단계, 이미지 1/1
    • Carefully slide the spudger between the ear pad and the speaker cover, along the seam, to remove the adhesive.
  3. Xbox One Stereo Headset Foam Ear Pads Replacement: 3 단계, 이미지 1/2 Xbox One Stereo Headset Foam Ear Pads Replacement: 3 단계, 이미지 2/2
    • Be careful not to tear the cloth ear pad cover.
    • Using your fingers, carefully pull the ear pad out from the black cloth cover.
    • When reinserting the foam ear pad, you may want to use a foam-safe adhesive to secure the back side of the foam to the plastic speaker cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Thor Watsjold
회원 가입일: 01/30/15
188 평판
안내서 1개 작성함
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G37
4 회원들
안내서 5개 작성하였습니다
댓글 3개
How do I glue/stick it back? =(
Dannylo - 답글
There is actually a much easier way to do this. Hold the ear cup in one hand with the plastic side down. Use your other hand to turn the pad counter clockwise until you hear a click. It should move no more than 1/4 of an inch. Now the two parts are separated and you will have access to the back of the large pad to replace the inner one.
therundi - 답글
Thanks therundi!
aesgene - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 27
전체 시간: 8,516
