주요 콘텐츠로 건너뛰기
Xbox One Stereo Headset Speaker Replacement
필요한 것
  1. Xbox One Stereo Headset Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
    • Do not grip the back of the speaker by the headband. Twisting this connection will break the headphone off the headband.
    • With the ear pad facing you, push down on the back plate and turn counter-clockwise to unlock the prongs holding it in place. The back plate will only rotate about 1 cm.
  2. Xbox One Stereo Headset Speaker Replacement: 2 단계, 이미지 1/1
    • Lift the back plate (with the ear pad attached) straight up from the speaker.
    • This should be very easy to do. If it doesn't come off easily, then the plate isn't fully rotated.
  3. Xbox One Stereo Headset Speaker Replacement: 3 단계, 이미지 1/1
    • Remove three 7 mm Phillips #00 screws holding the speaker in place.
  4. Xbox One Stereo Headset Speaker Replacement: 4 단계, 이미지 1/1
    • Carefully open the back casing, exposing the speaker wires.
  5. Xbox One Stereo Headset Speaker Replacement: 5 단계, 이미지 1/1
    • Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
    • Splice the headset wires to the corresponding replacement speaker wires.
    • Black connects to black, red connects to blue.
    • Although soldering isn't necessary when splicing wires, doing so creates a more reliable connection.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Shannon Prouty
회원 가입일: 01/30/15
781 평판
안내서 1개 작성함
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G37
4 회원들
안내서 5개 작성하였습니다
댓글 3개
what part is using to hold the speaker in place that you can adjust to fit your head
Nicholas Ryver - 답글
where can I buy the replacement speaker ?
Juan Carlos Sánchez Pulido - 답글
Can some help me with fixing a earmuff detached from the head band but the wires are still attached
Harry Obrastsoff-Rutinsky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 12,569
