주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller (1697 Model) D-pad Replacement
필요한 것
  1. Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: 1 단계, 이미지 1/3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: 1 단계, 이미지 2/3 Xbox One Wireless Controller (1697 Model) D-pad Replacement, D-pad: 1 단계, 이미지 3/3
    • Remove the side handles with the iFixit plastic opening tool by wedging it around the seam of the handles.
    • Be careful not to break the clips when removing the handles.
  2. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover and the batteries by sliding the cover up.
  3. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 3 단계, 이미지 1/1
    • Remove the two screws (four total screws) on the top and bottom of each controller handle and one screw underneath the battery pack using the T9 Torx screwdriver.
    • The screw underneath the battery pack is located under the sticker.
  4. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 4 단계, 이미지 1/3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: 4 단계, 이미지 2/3 Xbox One Wireless Controller (1697 Model) D-pad Replacement: 4 단계, 이미지 3/3
    • Remove the front cover of the controller. using the spudger.
  5. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 5 단계, 이미지 1/1
    • Remove the back cover of the controller using the spudger.
  6. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 6 단계, 이미지 1/2 Xbox One Wireless Controller (1697 Model) D-pad Replacement: 6 단계, 이미지 2/2
    • Remove the metal ring surrounding the D-pad.
  7. Xbox One Wireless Controller (1697 Model) D-pad Replacement: 7 단계, 이미지 1/1
    • Remove the D-pad from the device.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Ethan S
회원 가입일: 10/07/19
329 평판
안내서 1개 작성함
댓글 한 개
Hellow mine has a problem that it doesn't work\turn on with battery or with a cable like its dead
Abdulhamid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 110
전체 시간: 9,391
