주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment
필요한 것
    • Remove the batteries from your controller (if installed). If you do not have a TR8 screwdriver, the bit is in the Essential Electronics Toolkit.
    • Remove the screw under the battery cover label. To do this, puncture the label where it is marked. It is located roughly in the center of the battery bay on the controller.
    • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
    • Author's note: I have no intention of retaking these photos as I do not have my 1697 anymore (and avoid them when possible). I can do this with one hand, but using a pry tool in the area marked in orange makes this easier.
    • With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
    • With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
    • Remove the shell once the battery tabs are released.
    • Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
    • Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
    • Repair one trigger at a time!
    • Before cutting the heatshrink, make TWO alignment marks (non-crossing).
    • After making alignment marks, cut the heatshrink off using a utility knife.
    • Using the old heatshrink as a reference, cut two new pieces.
  1. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 5 단계, 이미지 1/3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 5 단계, 이미지 2/3 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): 5 단계, 이미지 3/3
    • Incorrect magnet alignment will result in LT/RT activation without human input.
    • After cutting the heatshrink tubing, do a test alignment before applying glue.
    • These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
    • Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
  2. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 6 단계, 이미지 1/2 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: 6 단계, 이미지 2/2
    • A controller frame may be required if done incorrectly. Verify the alignment before adding glue!
    • After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
    • Soft flame lighters may melt the plastic. Blue flame lighters are generally safer for this!
    • Once the glue cures, add new heatshrink tubing.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
84,559 평판
안내서 51개 작성하였습니다
Master Techs Master Techs 회원
Community
314 회원들
안내서 1,319개 작성하였습니다
댓글 4개
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
Eric Harper - 답글
same here cant find it any were
conman3609 -
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
Chawki Bourokba - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 78
30일 전: 281
전체 시간: 20,100
