주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xbox One Wireless Controller 1697 수리는 저희 서비스 설명서를 사용하십시오.
  1. Xbox One Wireless Controller 1697 Teardown, XBOX One Wireless Controller: 1 단계, 이미지 1/2 Xbox One Wireless Controller 1697 Teardown, XBOX One Wireless Controller: 1 단계, 이미지 2/2
    • Covert Forces model - Bowie 'Changes' look.
    • New 3.5mm jack socket next to expansion port.
  2. Xbox One Wireless Controller 1697 Teardown, Remove plastics: 2 단계, 이미지 1/3 Xbox One Wireless Controller 1697 Teardown, Remove plastics: 2 단계, 이미지 2/3 Xbox One Wireless Controller 1697 Teardown, Remove plastics: 2 단계, 이미지 3/3
    • Remove battery cover and battery
    • Remove side panels using spudger
    • Expose T9 security screw under label
    • Remove 5 x T9 security screws from chassis
    • Remove top and bottom covers
  3. Xbox One Wireless Controller 1697 Teardown, Tape down rumble motors: 3 단계, 이미지 1/2 Xbox One Wireless Controller 1697 Teardown, Tape down rumble motors: 3 단계, 이미지 2/2
    • Tape down the rumbler motors to prevent them from falling out.
  4. Xbox One Wireless Controller 1697 Teardown, Seperate PCB's: 4 단계, 이미지 1/2 Xbox One Wireless Controller 1697 Teardown, Seperate PCB's: 4 단계, 이미지 2/2
    • Remove 2 x T6 security screws on bottom PCB
    • De-solder rumble pack and trigger wiring
  5. Xbox One Wireless Controller 1697 Teardown, CODEC and Jack Socket: 5 단계, 이미지 1/2 Xbox One Wireless Controller 1697 Teardown, CODEC and Jack Socket: 5 단계, 이미지 2/2
    • Thar she blows! DA7212
    • Dialog Semiconductor CODEC with Class G HP AMP and Class AB speaker driver.
    • CODEC sits next to contact pads for 3.5mm jack socket
Bito Zapata
회원 가입일: 08/27/15
158 평판
안내서 1개 작성함
댓글 15개
Is it possible to show the other board? Was thinking of doing a scuf-style mod to one of these... Thanks
blazeclarkebcc - 답글
Was asking this because the boards are different to the older controller. I have PCB prints of the old one, but not the new one. Thanks.
blazeclarkebcc -
Can you point me where to get schematics that you have?
Piotr Zieliński -
Anybody know where I can get the new style bumpers for this style of controller? Any help would be greatly appreciated.
Rhys Jones - 답글
The guy I buy from on ebay said they would be available at the end of January
themadmaxof07 -
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 58
30일 전: 290
전체 시간: 70,712
