주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller 1697 Thumbstick Replacement
필요한 것
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: 1 단계, 이미지 1개 중 1개
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 2 단계, 이미지 2개 중 1개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 2 단계, 이미지 2개 중 2개
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 3 단계, 이미지 2개 중 2개
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 4 단계, 이미지 3개 중 1개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 4 단계, 이미지 3개 중 2개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back plate.
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the faceplate
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: 6 단계, 이미지 3개 중 1개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 6 단계, 이미지 3개 중 2개 Xbox One Wireless Controller 1697 Thumbstick  Replacement: 6 단계, 이미지 3개 중 3개
    • Select the thumbstick that you want to replace and pull it off its pole.
결론
다른 28명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Emely
회원 가입일: 09/27/17
866 평판
안내서 1개를 작성함
USF Tampa, Team S9-G1, Remmell Fall 2017 USF Tampa, Team S9-G1, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G1
4 회원들
안내서 14개를 작성함
1가이드 댓글
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 63
지난 30일: 211
전체 시간: 26,315
