주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Faceplate Replacement
필요한 것
  1. Xbox One Wireless Controller Faceplate Replacement, Battery Pack: 1 단계, 이미지 1/1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Faceplate Replacement, Side Handles: 2 단계, 이미지 1/2 Xbox One Wireless Controller Faceplate Replacement, Side Handles: 2 단계, 이미지 2/2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller Faceplate Replacement, Screws: 3 단계, 이미지 1/2 Xbox One Wireless Controller Faceplate Replacement, Screws: 3 단계, 이미지 2/2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller Faceplate Replacement, Backplate: 4 단계, 이미지 1/1
    • Remove the backplate.
  5. Xbox One Wireless Controller Faceplate Replacement, Faceplate: 5 단계, 이미지 1/1
    • Remove the faceplate.
결론
다른 87명이 해당 안내서를 완성하였습니다.
Tommy
회원 가입일: 01/22/15
1,915 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 회원
CPSU-MANESS-W15S20G15
5 회원들
안내서 52개 작성하였습니다
댓글 11개
It was a good tutorial, but i have two plastic rings that stay after my instervention... Anyone knows where are-they ?
Matis Begot - 답글
laurito andrea12 -
Note before starting. You need a T8 security bit (with a hole in the middle), not a standard T8 bit.
Fraser Currie - 답글
I took mine a part because it was looking dirty, gave it a good clean, putting it back together was easy but it wont work with the batteries anymore just the power core, there is nothing broken or cracked, any ideas?
Lee - 답글
Maybe you forced the battery contact on the wrong side of the case?
Alexandre Foley -
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 153
30일 전: 784
전체 시간: 239,579
