주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement, Bumper: 1 단계, 이미지 1개 중 1개
    • Remove the battery cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 2 단계, 이미지 3개 중 3개
    • Grip the controller firmly to remove the side handle cover.
    • Use a flathead screwdriver or a spudger to wedge between the seams of the front to the side handle of the controller.
    • Move the flathead screwdriver all the way around the side plates seam and push the plate forward.
  3. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 3 단계, 이미지 2개 중 2개
    • Use a screwdriver and punch a hole directly in the center label. There you will find a hidden screw.
    • Remove the five 10mm screws located on the back of the controller using a T8 screwdriver.
  4. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the backplate.
  5. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 5 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the faceplate.
  6. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 6 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 6 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the cover piece surrounding the Xbox button off of its pegs.
    • Firmly hold controller and push cover piece up from the pegs.
    • Press the Xbox button down to assist in the unclipping of the piece.
  7. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 7 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the broken bumper by unclipping it from its pegs.
    • Hold the controller firmly and push the bumper piece up from its pegs to unclip.
  8. Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 8 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 8 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1537 (Left) Bumper Replacement: 8 단계, 이미지 3개 중 3개
    • Align the replacement bumper onto the pegs, push gently and click into place.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cristyne Ramirez
회원 가입일: 01/24/18
661 평판
안내서 1개를 작성함
3가이드 댓글
On my controller the screws were T8 security type, so you'll need bits with a hole in the middle
Sean H - 답글 공유
Is there a way to do this without removing all of the front and grip.
Alan Marantos - 답글 공유
J'ai un problème c'est que j'arrive pas à retirer les 5 vis certaines sont bloqués j'ai l'impression vous auriez pas une solution
Ratz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 87
지난 30일: 440
전체 시간: 63,790
