주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 1 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: 1 단계, 이미지 2/2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 2 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 3 단계, 이미지 1/1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 4 단계, 이미지 1/3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 4 단계, 이미지 2/3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: 4 단계, 이미지 3/3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 5 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 5 단계, 이미지 2/2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: 6 단계, 이미지 1/1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
결론
다른 49명이 해당 안내서를 완성하였습니다.
Weston Gilmore
회원 가입일: 09/25/17
1,729 평판
안내서 1개 작성함
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 회원
CPSU-FORTE-F17S18G3
4 회원들
안내서 32개 작성하였습니다
댓글 4개
i used a t8 and it worked
Rudy Bp - 답글
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - 답글
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - 답글
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 70
30일 전: 285
전체 시간: 22,721
