주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Model 1708 Joystick Cap Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Cover Plate: 1 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Cover Plate: 1 단계, 이미지 2/2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 2 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - 답글
    Not a sharp of course.
    kajussls121 -
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - 답글
  3. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 3 단계, 이미지 1/1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - 답글
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - 답글
    The 2.0 minus worked for me as well.
    metric - 답글
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - 답글
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - 답글
  4. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: 4 단계, 이미지 1/3 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: 4 단계, 이미지 2/3 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: 4 단계, 이미지 3/3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 5 단계, 이미지 1/2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 5 단계, 이미지 2/2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: 6 단계, 이미지 1/1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - 답글
    It isn't necessary to take off the back cover
    Otto Hahn - 답글
  7. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Joystick Caps: 7 단계, 이미지 1/1
    • Pull the joysticks off of the controller.
    Are the joystick potentiometers soldered to the mother board or just push fit, this guide doesn’t mention soldering so I’m assuming the latter?
    Can you get genuine replacement joystick potentiometers as I’ve only seen cheap eBay type ones?
    Alan - 답글
    The actual joysticks themselves are soldered into the bottom motherboard.
    Bryan Remely -
    So where do i get new parts?
    mrdugi - 답글
결론
다른 133명이 해당 안내서를 완성하였습니다.
Dylan Gross
회원 가입일: 09/25/17
4,686 평판
안내서 4개 작성하였습니다
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 회원
CPSU-FORTE-F17S18G3
4 회원들
안내서 32개 작성하였습니다
댓글 6개
How about the square thing with the stick and hinges that the joystick is attached to? I think it’s called the Module. I have a joystick drift / drifting problem and that may help me out. Thanks.
Cory C - 답글
Agreed. That’s actually the part I need to replace too. The module.
Thomas Tomchak -
followed this guide to take the controller apart because I had a joystick that was sticking, my solution was to put some 3in1 oil on the module that was sticking and it seems to be working a lot better now.
John Jaggi - 답글
@corytc and @tomchak I did replace the module, in general, you buy (Amazon or eBay) you will receive a module of 6 modules you need a multimeter and test each module interface, measure both resistances and subtract them, the one nearest zero is the module you will use since is the one with least drift from the factory.
Just disassemble it, turn upside down uses a solder remover and unsolder the old one, place the new one solder back, boom you are done.
Like you will need an iron solder with medium and thin tips, I used lead-free solder, so is a patience test, be careful with the wires from the rumbles, try not to unsolder them since is a thin wire and is difficult, like I have big hands so took me a while to solder back.
Luis Vitorio Cargnini - 답글
Just want to say the hardest part is carefully prying off the plastic covers on the handles. It’s also not necessary to remove the back cover for simply replacing the joysticks. Other than that, it’s very easy. I would guess this is rated at moderate difficulty simply due to the plastic covers.
Will - 답글
Where can one get the replacement joysticks ?
Keven Dubois - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 110
30일 전: 583
전체 시간: 49,400
