이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to access and replace the top motherboard. Soldering is required, so the link to the soldering guide is included to help you.
필요한 것
Slide the battery cover toward the top of the controller to remove it.
Lift up the batteries or the battery pack from the battery compartment.
Tape the Rumbler/shock motors in place.
This will prevent the motors from falling out.
Turn the device over and remove the directional pad by gently pulling it away from the controller.
Turn the device over and remove the two 70mm torx-6 screws in the bottom left and right corners.
다른 20명이 해당 안내서를 완성하였습니다.
