주요 콘텐츠로 건너뛰기
Xbox One Wireless Controller Model 1708 Trigger Caps Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: 1 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement, Trigger Caps: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover out and remove it.
    • Remove the battery pack.
  2. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 2 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 2 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool between the handle and the plate.
    • Gently slide the opening tool from the top end to the bottom end of the seam to remove the plate from the handle.
    • Repeat the process with the other side plate.
    • The plate is tightly sealed on the handle, so it may be difficult to remove.
  3. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 3 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the five 2.3mm screws on the bottom plate with a T8 Torx security Screwdriver.
    • If there is a sticker on the back, poke a hole with the screwdriver to get to the fifth screw.
  4. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the bottom plate.
  5. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 5 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 5 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully turn over the controller with the front plate facing you.
    • Remove the front plate.
  6. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 6 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 6 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 1.7mm screws from each of the triggers with a T6 Torx screwdriver.
    • It is best to do one trigger cap replacement at a time.
  7. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 7 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 7 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 7 단계, 이미지 3개 중 3개
    • Be careful not to let the trigger motor inside come out.
    • Lift the trigger cap off the trigger motor.
  8. Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 8 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 8 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Trigger Caps Replacement: 8 단계, 이미지 3개 중 3개
    • Place the new trigger cap on the trigger motor.
    • Push down the inside of the trigger cap until you hear a click.
    • Repeat step six to eight for the other trigger cap.
결론
To reassemble your device, follow steps 1-5 in reverse order.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Lucero Cortes-Vitervo
회원 가입일: 02/18/20
563 평판
안내서 1개를 작성함
UC Davis, Team S1-G6, Andersen Winter 2020 UC Davis, Team S1-G6, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S1G6
3 회원들
안내서 4개를 작성함
1가이드 댓글
Et le reboitage stp non parce que je pense que ses le plus compliqué.
Yoann.cadenat - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 82
지난 30일: 368
전체 시간: 24,094
