주요 콘텐츠로 건너뛰기
Xbox One X Project Scorpio Edition Outer Case Replacement
필요한 것
  1. Xbox One X Project Scorpio Edition Outer Case Replacement, Outer Case: 1 단계, 이미지 1/2 Xbox One X Project Scorpio Edition Outer Case Replacement, Outer Case: 1 단계, 이미지 2/2
    • Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
  2. Xbox One X Project Scorpio Edition Outer Case Replacement: 2 단계, 이미지 1/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 2 단계, 이미지 2/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using precision tweezers, remove the screw tab located on opposite side of the box.
    • Use a T9 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
  3. Xbox One X Project Scorpio Edition Outer Case Replacement: 3 단계, 이미지 1/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 3 단계, 이미지 2/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 3 단계, 이미지 3/3
    • Orient the case so that the front of the Xbox (the side with the power button) is facing you.
    • Remove the top of the case by sliding the case towards you.
  4. Xbox One X Project Scorpio Edition Outer Case Replacement: 4 단계, 이미지 1/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 4 단계, 이미지 2/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 4 단계, 이미지 3/3
    • Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
    • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  5. Xbox One X Project Scorpio Edition Outer Case Replacement: 5 단계, 이미지 1/2 Xbox One X Project Scorpio Edition Outer Case Replacement: 5 단계, 이미지 2/2
    • Remove the unscrewed panel from the side of the device by pulling it toward you.
    • Be mindful of the connector, as it is fragile.
  6. Xbox One X Project Scorpio Edition Outer Case Replacement: 6 단계, 이미지 1/2 Xbox One X Project Scorpio Edition Outer Case Replacement: 6 단계, 이미지 2/2
    • Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
    • Do not force the connector out, as it is fragile. Wiggling may be necessary.
  7. Xbox One X Project Scorpio Edition Outer Case Replacement: 7 단계, 이미지 1/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 7 단계, 이미지 2/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 7 단계, 이미지 3/3
    • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
    • Remove both of these 7mm screws with a Torx T9 screwdriver.
    • Lift the detached plate off to the side.
    • The plate is still connected to the device.
  8. Xbox One X Project Scorpio Edition Outer Case Replacement: 8 단계, 이미지 1/2 Xbox One X Project Scorpio Edition Outer Case Replacement: 8 단계, 이미지 2/2
    • Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
  9. Xbox One X Project Scorpio Edition Outer Case Replacement: 9 단계, 이미지 1/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 9 단계, 이미지 2/3 Xbox One X Project Scorpio Edition Outer Case Replacement: 9 단계, 이미지 3/3
    • Turn the Xbox over, so that the bottom of the case is on top.
    • Lift the bottom of the case off of the Xbox by pulling it up and toward you.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Ashley Masuda
회원 가입일: 01/24/18
2,793 평판
안내서 7개 작성하였습니다
Cal Poly, Team S2-G6, Livingston Winter 2018 Cal Poly, Team S2-G6, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G6
4 회원들
안내서 23개 작성하였습니다
댓글 2개
Where do you get the outer case from? And if I only want to replace the outer case could I just follow the first 3 steps?
Daniel - 답글
Following. I need a replacement project Scorpio case. the system I got it from was from Mercari and the guy did a poor job in taking care of the case and I need a top Scorpio case.
Britteny X. Wilson -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 54
전체 시간: 5,422
