주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Battery Replacement
필요한 것
  1. Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the batteries: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the batteries: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Battery Replacement, Remove the batteries: 2 단계, 이미지 3개 중 3개
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
22,747 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
4가이드 댓글
Bro you have got to be joking
Aidan Pitts - 답글
this was a lifesaver
Desmay2 - 답글
Instructions Unclear: I've done those two steps, but the controller does not work anymore. I think something is missing.
Hey tea嘿茶 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 123
지난 30일: 392
전체 시간: 7,779
