주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement
필요한 것
  1. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the batteries: 2 단계, 이미지 3개 중 3개
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 3개
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 3개
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 3개
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 3개
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 3개
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 2개
    • Use a T8R Torx Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: 11 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: 11 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the top housing: 11 단계, 이미지 3개 중 3개
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: 12 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: 12 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the USB-C port cover: 12 단계, 이미지 3개 중 3개
    • The USB-C port cover is held in place by two plastic clips.
    • Insert the flat end of a spudger under the right USB-C port cover clip.
    • Pry up with the spudger to release the clip.
    • Repeat the procedure to release the left clip.
  13. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: 13 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the USB-C port cover: 13 단계, 이미지 2개 중 2개
    • Remove the USB-C port cover.
  14. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: 14 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: 14 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the right edge of the bumper cover: 14 단계, 이미지 3개 중 3개
    • Insert the point of a spudger between the clip on the outer edge of the right bumper and the midframe.
    • Pry out with the spudger to release the right side of the bumper cover.
  15. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: 15 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: 15 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Unclip the left edge of the bumper cover: 15 단계, 이미지 3개 중 3개
    • Insert the point of a spudger between the clip on the outer edge of the left bumper and the midframe.
    • Pry out with the spudger to release the left side of the bumper cover.
  16. Xbox Series X|S Controller (Model 1914) Bumper Cover Replacement, Remove the bumper cover: 16 단계, 이미지 1개 중 1개
    • Remove the bumper cover.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
22,863 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
4가이드 댓글
The left bumper button broke for me. The plastic post that presses the button just snapped. This helped me replace the bumper. Good guide.
Jordan Cooper - 답글
Removing the handle covers was the hardest part, largely because I was afraid I would break them if I asserted too much pressure. Once I got those off, it was pretty easy. The opening tool and spudger recommended in the tools section were useful--they did their jobs very well--but I suspect this could have been accomplished with any kind of replacement tool(s) you might have on hand; however, since I bought them I'm sure they'll come in handy in future projects. I would argue the TR8 Torx Security Screwdriver is really the only piece of equipment that is specifically required.
Russ Looney - 답글
£50 for a new controller, cost but £26 for the tools and spare part, took maybe 10 minutes, and you cannot tell one bit that my controller has been tampered with or fixed
feel truly accomplished, saved money - and now i have the tools for the next challenge, be it my own, or a friends'
Haydn Buchanan - 답글
I just broke the bumper cover while following steps 14 and 15 - the guide failed to mention the little plastic posts that actually press the RB/LB buttons are easily snapped while using the spudger to pry the bumper clips. The posts are visible in the picture for step 16 - the long protruding parts nearest the centre of the cover. Maybe consider adding a warning. I'm going to try to glue the posts back on but otherwise will have to just buy a replacement bumper cover part. Excellent guide otherwise.
owwynn - 답글
댓글 쓰기
조회 통계:
지난 24시간: 40
지난 7일: 339
지난 30일: 1,292
전체 시간: 25,665
