주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
필요한 것
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 1/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 2/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3/3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 1/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 2/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 3/3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 1/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 2/3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 3/3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Manuel Haeussermann
회원 가입일: 07/13/22
15,592 평판
안내서 71개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 23
30일 전: 103
전체 시간: 1,184
