주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
필요한 것
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 3개
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: 2 단계, 이미지 3개 중 3개
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: 3 단계, 이미지 3개 중 3개
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
22,747 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 34
지난 30일: 160
전체 시간: 3,652
