주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement
필요한 것
  1. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the batteries: 2 단계, 이미지 3개 중 3개
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 3개
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 3개
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 3개
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 3개
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 3개
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 2개
    • Use a T8R Torx Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 11 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 11 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the top housing: 11 단계, 이미지 3개 중 3개
    • Lift the top housing straight up to remove it.
  12. Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 12 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 12 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Thumbstick Covers Replacement, Remove the thumbstick covers: 12 단계, 이미지 3개 중 3개
    • Use your fingers to remove the joystick covers.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
22,747 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
3가이드 댓글
This was really helpful in fixing my thumbsticks. The only suggestion I have is to remove the battery cover after you're removed the handle covers instead of before. It will be easier to grip the controller while using the pry tools when the battery cover is still on.
Joshua Morden - 답글
Replaced the right thumb stick after mine broke. 3d printed a new stick and seems to be working fine. Thanks
Beau Belgard - 답글
Thanks so much, I fix it first time by this tutorial
Bruce Energy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 142
지난 30일: 523
전체 시간: 17,212
