주요 콘텐츠로 건너뛰기
Xbox Series X Base Replacement
필요한 것
  1. Xbox Series X Base Replacement, Unlatch the base: 1 단계, 이미지 3개 중 1개 Xbox Series X Base Replacement, Unlatch the base: 1 단계, 이미지 3개 중 2개 Xbox Series X Base Replacement, Unlatch the base: 1 단계, 이미지 3개 중 3개
    • Before you begin, completely power down and unplug all cables from your console.
    • A locking tab on the bottom of the shell (under the base) holds the base in place.
    • You can access the tab through the vent holes on the back of your Xbox, but you may need a flashlight. Alternatively, you can remove the back panel for easier access.
    • Stick a long, skinny flathead screwdriver through one of the vent holes on the back of your Xbox, near the locking tab.
    • Insert the screwdriver between the locking tab and the base. This might take a few tries—use a flashlight if you're having trouble.
    • Use the screwdriver to pry the tab inward (away from the base) into its open and unlocked position.
    • Keep the tab held open for the next step.
  2. Xbox Series X Base Replacement, Twist and remove the base: 2 단계, 이미지 3개 중 1개 Xbox Series X Base Replacement, Twist and remove the base: 2 단계, 이미지 3개 중 2개 Xbox Series X Base Replacement, Twist and remove the base: 2 단계, 이미지 3개 중 3개
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
결론
Congratulations on your repair!
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,272 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 29
전체 시간: 233
