주요 콘텐츠로 건너뛰기
Xbox Series X Optical Drive Replacement
필요한 것
  1. Xbox Series X Optical Drive Replacement, Uncover the back panel screws: 1 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement, Uncover the back panel screws: 1 단계, 이미지 2/2
    • Before starting this guide, power down your console and unplug all cables.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Optical Drive Replacement: 2 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement: 2 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement: 2 단계, 이미지 3/3
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers—but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    • Use a T8 Torx driver to remove the two 7.4 mm screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  3. Xbox Series X Optical Drive Replacement, Unclip the back panel: 4 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Unclip the back panel: 4 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Unclip the back panel: 4 단계, 이미지 3/3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pivot the spudger on the shell and pull up on the bottom of the back panel to release it from the locking clips.
  4. Xbox Series X Optical Drive Replacement: 5 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement: 5 단계, 이미지 2/2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  5. Xbox Series X Optical Drive Replacement, Remove the back panel: 6 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Remove the back panel: 6 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Remove the back panel: 6 단계, 이미지 3/3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  6. Xbox Series X Optical Drive Replacement: 7 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement: 7 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement: 7 단계, 이미지 3/3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  7. Xbox Series X Optical Drive Replacement, Unlatch the base: 8 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Unlatch the base: 8 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Unlatch the base: 8 단계, 이미지 3/3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  8. Xbox Series X Optical Drive Replacement, Twist and remove the base: 9 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Twist and remove the base: 9 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Twist and remove the base: 9 단계, 이미지 3/3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  9. Xbox Series X Optical Drive Replacement, Remove the optical drive screws: 10 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement, Remove the optical drive screws: 10 단계, 이미지 2/2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  10. Xbox Series X Optical Drive Replacement, Remove the vibration isolator: 11 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Remove the vibration isolator: 11 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Remove the vibration isolator: 11 단계, 이미지 3/3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  11. Xbox Series X Optical Drive Replacement, Disconnect the power and data cables: 12 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement, Disconnect the power and data cables: 12 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement, Disconnect the power and data cables: 12 단계, 이미지 3/3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Always pull cables by their connectors and not the wires themselves.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  12. Xbox Series X Optical Drive Replacement, Remove the optical drive: 13 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement, Remove the optical drive: 13 단계, 이미지 2/2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  13. Xbox Series X Optical Drive Replacement, Remove the optical drive cover: 14 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the four 3.6 mm screws securing the optical drive cover.
  14. Xbox Series X Optical Drive Replacement: 15 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement: 15 단계, 이미지 2/2
    • Lift the optical drive cover straight up to remove it.
  15. Xbox Series X Optical Drive Replacement, Disconnect the three ribbon cables: 16 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement, Disconnect the three ribbon cables: 16 단계, 이미지 2/2
    • Use the pointed end of a spudger to flip up the hinged locking tab on the large ribbon cable's ZIF connector.
  16. Xbox Series X Optical Drive Replacement: 17 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement: 17 단계, 이미지 2/2
    • Use the pointed end of a spudger to flip up the hinged locking tab on the small ribbon cable's ZIF connector.
  17. Xbox Series X Optical Drive Replacement: 18 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement: 18 단계, 이미지 2/2
    • Use the pointed end of a spudger to flip up the hinged locking tab on the small ribbon cable's ZIF connector, near the corner of the optical drive.
  18. Xbox Series X Optical Drive Replacement: 19 단계, 이미지 1/3 Xbox Series X Optical Drive Replacement: 19 단계, 이미지 2/3 Xbox Series X Optical Drive Replacement: 19 단계, 이미지 3/3
    • Use a pair of blunt tweezers to remove each of the three ribbon cables from their connectors.
    • Always pull ribbon cables straight out of their connectors, in the direction of the cable.
  19. Xbox Series X Optical Drive Replacement, Desolder the two wires: 20 단계, 이미지 1/2 Xbox Series X Optical Drive Replacement, Desolder the two wires: 20 단계, 이미지 2/2
    • Use a soldering iron to desolder the red wire in the corner of the disc drive circuit board.
    • Then, desolder the adjacent black wire. Use a pair of blunt tweezers to hold and pull away the wires from the circuit board.
    • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
    • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long periods of time.
    • When you install the original circuit board into the replacement disc drive, solder the red wire to the solder pad labeled R. Solder the black wire to the solder pad labeled B.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
다른 5명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
92,138 평판
안내서 337개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,707개 작성하였습니다
4 댓글
Where can I get a replacement disk drive for my Series X? Figures the warranty just ran out last month and now the disk drive wants to start acting stupid. Doing the same exact thing my One X did where it'll read some discs no problem but won't read others. Just got Guardians of the Galaxy brand new, first time ever taking it out of it's case and inserted directly into the console and it won't read.
NISMOJukeRich - 답글
After zooming into the drive cover, we find the model number is DG-6M5S-03B Which can then be googled, to find that its the exact same replacement drive from previous xbox models. The only difference being the drives motherboard, which you will be swapping to your current one anyway.
Veronica Lowe -
Where can I get replacement drive?
anthonyt204 - 답글
After zooming into the drive cover, we find the model number is DG-6M5S-03B Which can then be googled, to find that its the exact same replacement drive from previous xbox models. The only difference being the drive's motherboard, which you will be swapping to your current one anyway.
Veronica Lowe -
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 145
30일 전: 555
전체 시간: 8,349
