주요 콘텐츠로 건너뛰기
Xelio P1001A-BK Rear Camera Replacement
필요한 것
  1. Xelio P1001A-BK Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Xelio P1001A-BK Rear Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Rear Camera Replacement: 2 단계, 이미지 1/2 Xelio P1001A-BK Rear Camera Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Rear Camera Replacement, Rear Camera: 3 단계, 이미지 1/1
    • Locate ribbon connector, make sure it is secure.
  4. Xelio P1001A-BK Rear Camera Replacement: 4 단계, 이미지 1/1
    • With a plastic opening tool, gently pry the camera body from its retaining socket
  5. Xelio P1001A-BK Rear Camera Replacement: 5 단계, 이미지 1/1
    • Make sure the camera is unobstructed
  6. Xelio P1001A-BK Rear Camera Replacement: 6 단계, 이미지 1/3 Xelio P1001A-BK Rear Camera Replacement: 6 단계, 이미지 2/3 Xelio P1001A-BK Rear Camera Replacement: 6 단계, 이미지 3/3
    • If there is still no picture, remove the securing tab on the ribbon connector by inserting the plastic opening tool between the tab on the ribbon cable connector body.
    • Slowly twist the opening tool to loosen the tab. Move the screwdriver to different parts of the tab to move it a little bit at a time.
    • Once the tab is loose, remove it then slide the ribbon cable from its connector and remove the camera from the tablet
  7. Xelio P1001A-BK Rear Camera Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • With a microfiber lens cleaning cloth, clean the camera lens
  8. Xelio P1001A-BK Rear Camera Replacement: 8 단계, 이미지 1/3 Xelio P1001A-BK Rear Camera Replacement: 8 단계, 이미지 2/3 Xelio P1001A-BK Rear Camera Replacement: 8 단계, 이미지 3/3
    • To install a new camera, slide the ribbon cable back into its connector
    • Reinstall the ribbon cable securing tab
    • Note the indentation that goes along the edge of the securing tab. It must be facing up to orient the tab correctly
    • Install the camera in its retaining socket
결론
Caleb
회원 가입일: 03/11/15
101 평판
안내서 1개 작성함
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 회원
UCCS-PANKO-S15S4G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 124
