주요 콘텐츠로 건너뛰기
Xelio P1001A-BK Wi-Fi Antenna Replacement
필요한 것
  1. Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: 1 단계, 이미지 1/2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Wi-Fi Antenna Replacement: 2 단계, 이미지 1/2 Xelio P1001A-BK Wi-Fi Antenna Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: 3 단계, 이미지 1/2 Xelio P1001A-BK Wi-Fi Antenna Replacement, Wi-Fi Antenna: 3 단계, 이미지 2/2
    • Desolder the connection on the motherboard.
    • Use a soldering vacuum to remove any excess solder.
  4. Xelio P1001A-BK Wi-Fi Antenna Replacement: 4 단계, 이미지 1/1
    • Use wire strippers to strip off at least 2 mm of wire insulation from each wire.
  5. Xelio P1001A-BK Wi-Fi Antenna Replacement: 5 단계, 이미지 1/1
    • Solder the outer wire braid shield to the ground point.
  6. Xelio P1001A-BK Wi-Fi Antenna Replacement: 6 단계, 이미지 1/1
    • Solder the center conductor to the antenna point.
결론
Josh Saenz
회원 가입일: 03/11/15
316 평판
안내서 3개 작성하였습니다
Colorado Springs, Team 4-2, Panko Spring 2015 Colorado Springs, Team 4-2, Panko Spring 2015 회원
UCCS-PANKO-S15S4G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 149
