주요 콘텐츠로 건너뛰기
Xelio P900A-BK Front Facing Camera Replacement
필요한 것
  1. Xelio P900A-BK Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/1
    • Remove the two 5.4mm bottom screws.
    • Set aside.
  2. Xelio P900A-BK Front Facing Camera Replacement: 2 단계, 이미지 1/3 Xelio P900A-BK Front Facing Camera Replacement: 2 단계, 이미지 2/3 Xelio P900A-BK Front Facing Camera Replacement: 2 단계, 이미지 3/3
    • Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
    • Gently work your way around the entire tablet and do not force the case open prematurely.
    • You will hear the plastic latches pop free.
  3. Xelio P900A-BK Front Facing Camera Replacement: 3 단계, 이미지 1/1
    • Remove the connection between the camera and the motherboard.
    • Open the black ribbon holder then remove the ribbon from its connection.
  4. Xelio P900A-BK Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
  5. Xelio P900A-BK Front Facing Camera Replacement: 5 단계, 이미지 1/3 Xelio P900A-BK Front Facing Camera Replacement: 5 단계, 이미지 2/3 Xelio P900A-BK Front Facing Camera Replacement: 5 단계, 이미지 3/3
    • Use the smaller plastic opening tool to remove the camera from its socket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marcus Nelson
회원 가입일: 03/26/15
307 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 96
