주요 콘텐츠로 건너뛰기
Xi-Electronics 7 inch Tablet DC Jack Replacement
필요한 것
  1. Xi-Electronics 7 inch Tablet DC Jack Replacement, dc jack recharger connector: 1 단계, 이미지 2개 중 1개 Xi-Electronics 7 inch Tablet DC Jack Replacement, dc jack recharger connector: 1 단계, 이미지 2개 중 2개
    • to open the device , You use a isesamo opener .
    • Just pry the device open but be gently and cautious
    • at the second picture you see how the inside looks like.
  2. Xi-Electronics 7 inch Tablet DC Jack Replacement: 2 단계, 이미지 2개 중 1개 Xi-Electronics 7 inch Tablet DC Jack Replacement: 2 단계, 이미지 2개 중 2개
    • now gently remove the first connector circkled in red
    • use a toothpick dental tool to open it. or use a small flathead screwdriver or something similar.
  3. Xi-Electronics 7 inch Tablet DC Jack Replacement: 3 단계, 이미지 3개 중 1개 Xi-Electronics 7 inch Tablet DC Jack Replacement: 3 단계, 이미지 3개 중 2개 Xi-Electronics 7 inch Tablet DC Jack Replacement: 3 단계, 이미지 3개 중 3개
    • remove the second connector.
    • first remove the orange tape by peeling it of.
    • then remove the black thick tape on the connecotr
  4. Xi-Electronics 7 inch Tablet DC Jack Replacement: 4 단계, 이미지 1개 중 1개
    • remove the third connecor , it is next to the connecotr in step 3.
  5. Xi-Electronics 7 inch Tablet DC Jack Replacement: 5 단계, 이미지 1개 중 1개
    • remove the screws of the main board.
  6. Xi-Electronics 7 inch Tablet DC Jack Replacement: 6 단계, 이미지 2개 중 1개 Xi-Electronics 7 inch Tablet DC Jack Replacement: 6 단계, 이미지 2개 중 2개
    • after removing the mainboard , you'll see the missing dc jack.
    • we will solder the dc jack on the main board.
    • before you do this, search the internet on how you have to solder !! and use the right tools, dont buy the cheapest tools.
  7. Xi-Electronics 7 inch Tablet DC Jack Replacement: 7 단계, 이미지 1개 중 1개
    • i didn't put pictures or movie on how to solder in this guide, but you will find lots of info on the internet. in the last picture you'll see the new dc jack.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin D
회원 가입일: 05/02/14
7,406 평판
안내서 21개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 18
전체 시간: 2,291
