주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Battery Replacement
필요한 것
  1. Xiaomi Air 12 Battery Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Battery Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Air 12 Battery Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Air 12 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Battery Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Air 12 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Battery Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Air 12 Battery Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Air 12 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Battery Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Air 12 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Battery Replacement, SSD: 6 단계, 이미지 2개 중 1개 Xiaomi Air 12 Battery Replacement, SSD: 6 단계, 이미지 2개 중 2개
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Battery Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Air 12 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Battery Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Air 12 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Battery Replacement, Battery: 9 단계, 이미지 1개 중 1개
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Battery Replacement: 10 단계, 이미지 3개 중 1개 Xiaomi Air 12 Battery Replacement: 10 단계, 이미지 3개 중 2개 Xiaomi Air 12 Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Battery Replacement: 11 단계, 이미지 3개 중 1개 Xiaomi Air 12 Battery Replacement: 11 단계, 이미지 3개 중 2개 Xiaomi Air 12 Battery Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Kwan
회원 가입일: 04/18/18
869 평판
안내서 5개를 작성함
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G4
4 회원들
안내서 20개를 작성함
댓글 6개
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
Migwell2 - 답글
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
Roma Monica Desunia - 답글
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot -
after I change the battery it always says plugged in not charge, anyone has the same issue?
Anthony Jethro Lieander - 답글
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hamed Mirrezaee - 답글
댓글 쓰기
조회 통계:
지난 24시간: 92
지난 7일: 795
지난 30일: 853
전체 시간: 9,554
