주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Motherboard Replacement
필요한 것
  1. Xiaomi Air 12 Motherboard Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Motherboard Replacement, SSD: 6 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement, SSD: 6 단계, 이미지 2개 중 2개
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Motherboard Replacement, Battery: 9 단계, 이미지 1개 중 1개
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
  12. Xiaomi Air 12 Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
    • Lift the silver connection cover next to the USB ports using the plastic opening tool and your hands.
  13. Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the four ribbon cables by lifting the connector up with the plastic opening tool and pulling the ribbon cable out.
  14. Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Disconnect the gray and black wire connectors using the plastic opening tool to lift them up.
  15. Xiaomi Air 12 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the webcam connector by gently pulling the cable out by hand.
  16. Xiaomi Air 12 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the video cable on the connector using the plastic opening tool to disconnect it.
  17. Xiaomi Air 12 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the seven black 2mm screws using a PH1 screwdriver.
  18. Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
    • Gently lift the motherboard out by hand.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Kwan
회원 가입일: 04/18/18
869 평판
안내서 5개를 작성함
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G4
4 회원들
안내서 23개를 작성함
댓글 11개
Where do you order a replacement?
I couldn’t find any parts for my Xiaomi air 12.
Jon Jag - 답글
di you get it?
zelenmix -
Same here. Where to get motherboard to xiaomi mi 12?
imthespace - 답글
Did yoiu get it?
zelenmix -
... I would like to replace but I can't find a motherboard anywhere ... can anyone help me, where to buy the board for best price?
Aljoša Jelen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 149
지난 30일: 353
전체 시간: 4,967
