주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Screen Replacement
필요한 것
    • Remove the screws on the back. 1 of them is under the rubber pads in the center
    • Remove the back gently. Screen replacement stick can help. There are several plastic holding it.
    • Remove the connectors going to the screen. 2 wifi cables near the battery. One camera cable halfway to the carger. One screen cable on at the HDMI.
    • Remove the screws holding the hinges on the corners. 4 screws holding them.
    • Turn the hinges upwards till 90 degrees.
    • Remove the screen from the main board.
    • Remove 2 screws from the bottom.
    • pull the screen towards the place of the screws and it will come out.
    • Remove the screen. Remove the connector cable.
    • Check if the cable was wrong not the whole screen.
    • Do everything backwards.
    • Connect the cable.
    • Push the new screen away from the places of the screws.
    • Add the screws.
    • Put back the whole together. Turn the hinges back.
    • Add the screws to the holes marked with a triangle.
    • Reconnect the cables to the main board.
    • Put back the lid of the main board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Robin Csutorás
회원 가입일: 04/09/19
133 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 127
전체 시간: 400
