필요한 것
Remove the screws on the back. 1 of them is under the rubber pads in the center
Remove the back gently. Screen replacement stick can help. There are several plastic holding it.
Do everything backwards.
Connect the cable.
Push the new screen away from the places of the screws.
Add the screws.
Put back the whole together. Turn the hinges back.
Add the screws to the holes marked with a triangle.
Reconnect the cables to the main board.
Put back the lid of the main board.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
