주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Speaker Replacement
필요한 것
  1. Xiaomi Air 12 Speaker Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Air 12 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Air 12 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Speaker Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Air 12 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Air 12 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Air 12 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Speaker Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Air 12 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 1개 Xiaomi Air 12 Speaker Replacement, Speaker: 6 단계, 이미지 2개 중 2개
    • Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
  7. Xiaomi Air 12 Speaker Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Air 12 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull the speaker connector out from the connection point using your hand.
  8. Xiaomi Air 12 Speaker Replacement: 8 단계, 이미지 3개 중 1개 Xiaomi Air 12 Speaker Replacement: 8 단계, 이미지 3개 중 2개 Xiaomi Air 12 Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the left speaker module by pulling the panel up from the device.
    • Repeat the same process for the right speaker module.
    • Left and Right speaker modules are denoted by an "L" and "R" respectively.
    • There will be a slight adhesive underneath the module.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hannah Kwan
회원 가입일: 04/18/18
869 평판
안내서 5개를 작성함
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G4
4 회원들
안내서 20개를 작성함
댓글 6개
Thanks for the tutorial! But where can i buy replacement speakers? My right speaker is overdriving all the time now, giving me a lot of loud buzz noises.
Nicolai - 답글
The same for me. I’d like to replace the speakers because one of them is “crackling/vibrating”, but i don’t know where to buy them…
Maniac 45 - 답글
same problem, mine at >50% vibrating very bad
isman87 - 답글
have you found them? i need those too
Giorgio Pianesi -
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
James Prae Liclican - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 104
지난 30일: 109
전체 시간: 1,219
