주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Trackpad Replacement
필요한 것
  1. Xiaomi Air 12 Trackpad Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Trackpad Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Air 12 Trackpad Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Air 12 Trackpad Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Trackpad Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Trackpad Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Air 12 Trackpad Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Air 12 Trackpad Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Trackpad Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Trackpad Replacement, SSD: 6 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement, SSD: 6 단계, 이미지 2개 중 2개
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Trackpad Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Trackpad Replacement, Battery: 9 단계, 이미지 1개 중 1개
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Trackpad Replacement: 10 단계, 이미지 3개 중 1개 Xiaomi Air 12 Trackpad Replacement: 10 단계, 이미지 3개 중 2개 Xiaomi Air 12 Trackpad Replacement: 10 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Trackpad Replacement: 11 단계, 이미지 3개 중 1개 Xiaomi Air 12 Trackpad Replacement: 11 단계, 이미지 3개 중 2개 Xiaomi Air 12 Trackpad Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
  12. Xiaomi Air 12 Trackpad Replacement, Trackpad: 12 단계, 이미지 1개 중 1개
    • Orient the computer so that the trackpad is closest to you.
  13. Xiaomi Air 12 Trackpad Replacement: 13 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 13 단계, 이미지 2개 중 2개
    • Disconnect the trackpad cable from the motherboard by inserting the plastic opening tool under the white tab of the connector and pry up the white tab.
  14. Xiaomi Air 12 Trackpad Replacement: 14 단계, 이미지 1개 중 1개
    • Gently remove the cable by pulling it out from the connector.
  15. Xiaomi Air 12 Trackpad Replacement: 15 단계, 이미지 2개 중 1개 Xiaomi Air 12 Trackpad Replacement: 15 단계, 이미지 2개 중 2개
    • Use a PH1 screwdriver to remove the three 2 mm screws.
  16. Xiaomi Air 12 Trackpad Replacement: 16 단계, 이미지 3개 중 1개 Xiaomi Air 12 Trackpad Replacement: 16 단계, 이미지 3개 중 2개 Xiaomi Air 12 Trackpad Replacement: 16 단계, 이미지 3개 중 3개
    • Lift the top end of the trackpad at a small angle and pull the trackpad out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hannah Kwan
회원 가입일: 04/18/18
869 평판
안내서 5개를 작성함
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G4
4 회원들
안내서 20개를 작성함
댓글 한 개
Hi. where can i find this touchpad? actually for 13.3 one
Alex Palance - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 90
지난 30일: 96
전체 시간: 2,090
