주요 콘텐츠로 건너뛰기
Xiaomi Mi 4 Battery Replacement
필요한 것
  1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 1 단계, 이미지 3개 중 1개 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 1 단계, 이미지 3개 중 2개 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: 1 단계, 이미지 3개 중 3개
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Battery Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Mi 4 Battery Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Mi 4 Battery Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Metal Spudger
    $2.99
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Battery Replacement: 3 단계, 이미지 3개 중 1개 Xiaomi Mi 4 Battery Replacement: 3 단계, 이미지 3개 중 2개 Xiaomi Mi 4 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Xiaomi Mi 4 Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Xiaomi Mi 4 Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Battery Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Mi 4 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
결론
다른 48명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
William Pendeergraft
회원 가입일: 09/08/15
2,441 평판
안내서 4개를 작성함
USF Tampa, Team 15-6, Blackwell Fall 2015 USF Tampa, Team 15-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G6
2 회원들
안내서 11개를 작성함
댓글 24개
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - 답글
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker -
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - 답글
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 69
지난 30일: 158
전체 시간: 148,535
