주요 콘텐츠로 건너뛰기
Xiaomi Mi 4 Rear Facing Camera Replacement
필요한 것
  1. Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: 1 단계, 이미지 1/3 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: 1 단계, 이미지 2/3 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Case/Midframe: 1 단계, 이미지 3/3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  2. Xiaomi Mi 4 Rear Facing Camera Replacement: 3 단계, 이미지 1/3 Xiaomi Mi 4 Rear Facing Camera Replacement: 3 단계, 이미지 2/3 Xiaomi Mi 4 Rear Facing Camera Replacement: 3 단계, 이미지 3/3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  3. Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 1/3 Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 2/3 Xiaomi Mi 4 Rear Facing Camera Replacement, Battery: 4 단계, 이미지 3/3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  4. Xiaomi Mi 4 Rear Facing Camera Replacement: 5 단계, 이미지 1/2 Xiaomi Mi 4 Rear Facing Camera Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
  5. Xiaomi Mi 4 Rear Facing Camera Replacement, Motherboard: 6 단계, 이미지 1/1
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
  6. Xiaomi Mi 4 Rear Facing Camera Replacement: 7 단계, 이미지 1/2 Xiaomi Mi 4 Rear Facing Camera Replacement: 7 단계, 이미지 2/2
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
  7. Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Facing Camera: 8 단계, 이미지 1/2 Xiaomi Mi 4 Rear Facing Camera Replacement, Rear Facing Camera: 8 단계, 이미지 2/2
    • With the motherboard removed from the device, turn the motherboard over to face the obverse side.
    • Locate the connector for the rear camera.
  8. Xiaomi Mi 4 Rear Facing Camera Replacement: 9 단계, 이미지 1/3 Xiaomi Mi 4 Rear Facing Camera Replacement: 9 단계, 이미지 2/3 Xiaomi Mi 4 Rear Facing Camera Replacement: 9 단계, 이미지 3/3
    • Grasp the cable with the tweezers and gently pull up and away from the motherboard to disconnect it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
William Pendeergraft
회원 가입일: 09/08/15
2,350 평판
안내서 4개 작성하였습니다
USF Tampa, Team 15-6, Blackwell Fall 2015 USF Tampa, Team 15-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G6
2 회원들
안내서 10개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 4,208
