주요 콘텐츠로 건너뛰기
Xiaomi Mi A2 Motherboard Replacement
필요한 것
  1. Xiaomi Mi A2 Motherboard Replacement, Screen: 1 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement, Screen: 1 단계, 이미지 2/2
    • Turn off your phone before proceeding.
    • Remove SIM card tray from phone.
    • Touch something metallic to ensure you are electrostatic safe.
  2. Xiaomi Mi A2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the two 2.7mm Pentalobe #2 screws from the bottom of the phone.
  3. Xiaomi Mi A2 Motherboard Replacement: 3 단계, 이미지 1/3 Xiaomi Mi A2 Motherboard Replacement: 3 단계, 이미지 2/3 Xiaomi Mi A2 Motherboard Replacement: 3 단계, 이미지 3/3
    • Grab a suction cup tool and place it near the bottom of the phone.
    • Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
    • Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
    • Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
    • Flip the phone screen towards the bottom of the device and lay the screen facing down.
    • Note: The ribbon cable is in the middle of the panel, thus there is no need to be cautious about snagging a ribbon cable
  4. Xiaomi Mi A2 Motherboard Replacement: 4 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 4 단계, 이미지 2/2
    • When removing the ribbon cable and installing the new one take special care to not bend or fold the cable too much as this can cause damage to the cable itself.
    • To access the ribbon cable connectors we must remove the metal bracket.
    • Remove the three 2.4mm Philips #0 screws that hold the panel down.
  5. Xiaomi Mi A2 Motherboard Replacement: 5 단계, 이미지 1/3 Xiaomi Mi A2 Motherboard Replacement: 5 단계, 이미지 2/3 Xiaomi Mi A2 Motherboard Replacement: 5 단계, 이미지 3/3
    • Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
    • Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
    • After you remove the ribbon cable the panel should be free to remove and replace.
  6. Xiaomi Mi A2 Motherboard Replacement, USB Port: 6 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement, USB Port: 6 단계, 이미지 2/2
    • Remove the two 3.8mm Phillips #0 screws holding down the lower metal bracket.
  7. Xiaomi Mi A2 Motherboard Replacement: 7 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the loud speaker. There are three 2.4mm Phillips #0 screws you need to remove, and one (upper right) is underneath the Xiaomi water sticker.
  8. Xiaomi Mi A2 Motherboard Replacement: 8 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 8 단계, 이미지 2/2
    • Unplug the antenna wire with a spudger tool.
    • Remove another 2.4mm Phillips #0 screw near vibration motor.
  9. Xiaomi Mi A2 Motherboard Replacement: 9 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 9 단계, 이미지 2/2
    • The ribbon cable connector is located underneath the sub-board. To access the connector flip the board over towards the battery.
    • Use a spudger tool to remove the cable from the connector.
    • The USB Connector board can now be removed from the device and replaced.
  10. Xiaomi Mi A2 Motherboard Replacement, Battery: 10 단계, 이미지 1/3 Xiaomi Mi A2 Motherboard Replacement, Battery: 10 단계, 이미지 2/3 Xiaomi Mi A2 Motherboard Replacement, Battery: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • On the bottom of the battery are two pull tabs. They are glued on to the battery similarly like a sticker.
    • To remove the battery pull these pull tabs downwards. WARNING: proceed with extreme caution, avoid bending or puncturing the battery.
    • You can use tweezers to lift the pull tabs from the battery. Pull downwards and the adhesive will slowly be removed from the battery.
  11. Xiaomi Mi A2 Motherboard Replacement: 11 단계, 이미지 1/1
    • Gently remove battery from its housing.
    • Component can now be replaced.
  12. Xiaomi Mi A2 Motherboard Replacement, Front Camera: 12 단계, 이미지 1/1
    • Using a plastic spudger, gently separate the front camera ribbon cable from the motherboard.
  13. Xiaomi Mi A2 Motherboard Replacement: 13 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 13 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently use the plastic tip tweezers to remove the front camera from the back housing of the phone.
  14. Xiaomi Mi A2 Motherboard Replacement, Motherboard: 14 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement, Motherboard: 14 단계, 이미지 2/2
    • Using a plastic spudger, gently disconnect the Motherboard to SUB board flex connector from the motherboard.
    • Using a plastic spudger, gently disconnect the fingerprint sensor connector from the motherboard.
  15. Xiaomi Mi A2 Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the two 2 mm Philips #0 screws from the motherboard.
    • Remove the two 2.5 mm Philips #0 screws from the motherboard.
    • Remove the one 1.5 mm Philips #0 screws from the motherboard.
  16. Xiaomi Mi A2 Motherboard Replacement: 16 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 16 단계, 이미지 2/2
    • Using the pointed end of plastic spudger, pry the motherboard away from the back housing.
  17. Xiaomi Mi A2 Motherboard Replacement: 17 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the fine tipped tweezers, remove the network antenna wire from the back of the motherboard.
  18. Xiaomi Mi A2 Motherboard Replacement: 18 단계, 이미지 1/3 Xiaomi Mi A2 Motherboard Replacement: 18 단계, 이미지 2/3 Xiaomi Mi A2 Motherboard Replacement: 18 단계, 이미지 3/3
    • Using a plastic spudger and plastic tipped tweezers, carefully peal back the adhered copper sheeting from the back of the rear cameras.
  19. Xiaomi Mi A2 Motherboard Replacement: 19 단계, 이미지 1/2 Xiaomi Mi A2 Motherboard Replacement: 19 단계, 이미지 2/2
    • Using a plastic spudger, gently separate the two rear camera ribbon cables from the motherboard.
    • Gently remove the rear cameras from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Zachary Parker
회원 가입일: 09/24/18
724 평판
안내서 4개 작성하였습니다
댓글 한 개
What is the price of new mother board of this phone
Ilyas Qabool - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 114
전체 시간: 6,108
