메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. Turn off and remove the SIM Card Turn off and remove the SIM Card
    • Turn off and remove the SIM Card
  2. Applay heat on to losen the back cover adhesiv.Then remove it carfully. Applay heat on to losen the back cover adhesiv.Then remove it carfully. Applay heat on to losen the back cover adhesiv.Then remove it carfully.
    • Applay heat on to losen the back cover adhesiv.Then remove it carfully.
  3. Remove all 9 screws that holds the sheeld protecting the motherboard Remove all 9 screws that holds the sheeld protecting the motherboard
    • Remove all 9 screws that holds the sheeld protecting the motherboard
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Remove the sheeled and desconect the Battery connector,LCD+Touch connector and Touch ID Connector. Remove the sheeled and desconect the Battery connector,LCD+Touch connector and Touch ID Connector. Remove the sheeled and desconect the Battery connector,LCD+Touch connector and Touch ID Connector.
    • Remove the sheeled and desconect the Battery connector,LCD+Touch connector and Touch ID Connector.
  6. Remove the battery carfully as showen.and applay heat to losen the adhesives holding the screen. Remove the battery carfully as showen.and applay heat to losen the adhesives holding the screen. Remove the battery carfully as showen.and applay heat to losen the adhesives holding the screen.
    • Remove the battery carfully as showen.and applay heat to losen the adhesives holding the screen.
  7. Carefully start to separet the screen as showen.start from the top corner. Carefully start to separet the screen as showen.start from the top corner. Carefully start to separet the screen as showen.start from the top corner.
    • Carefully start to separet the screen as showen.start from the top corner.
  8. You have done it. You have done it.
    • You have done it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kefelegn Derbew
회원 가입일: 2014년 06월 23일
145 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 45
지난 30일: 147
전체 시간: 453
