소개
Use this guide to replace your Xiaomi Mi Note's rear facing camera.
필요한 것
Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
With the onset of the new year, the world of smartphones is looking forward to the launch of Xiaomi Mi6, the next flagship launch in the series of Mi phones.
The Mi 5 received a lot of positive feedback when it launched last year, so we can expect that the Mi6 is going to be even better than its predecessor.
You can check out my site http://mi6splus.com/xiaomi-mi-6-features... for more info about the same.
