소개
Use this guide to replace your Xiaomi Mi Note's screen display.
필요한 것
Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
No need to remove the lower part.
Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
Be careful not to turntoo much the top left screw, next to the lens. It's close to the white film of the screen , you may hurt it (i did)
Use a spudger to detach the ribbons connected to the motherboard using an upward prying motion.
Apply considerable force to the back corners using your spudger to help relieve it of the adhesive as shown.
Once you have freed the screen from a portion of the adhesive, wedge your spudger around the front edge to work around the edges of the screen and frame in order to fully remove it from the frame.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 3개
Hello, I have unmounted my mi note pro to change the battery. I successfully changed it but now my phone's touch screen does not work anymore. The screen displays but the touch function doesn't work. Can someone help me identify the part I might have damaged or disconnected accidentally?
