주요 콘텐츠로 건너뛰기
Xiaomi Mi Pad Battery Replacement
필요한 것
  1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: 1 단계, 이미지 1/1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Battery Replacement: 2 단계, 이미지 1/2 Xiaomi Mi Pad Battery Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Battery Replacement, Battery: 3 단계, 이미지 1/2 Xiaomi Mi Pad Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Battery Replacement: 4 단계, 이미지 1/1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Battery Replacement: 5 단계, 이미지 1/2 Xiaomi Mi Pad Battery Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to disconnect the three ribbon cable connectors.
    • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
  6. Xiaomi Mi Pad Battery Replacement: 6 단계, 이미지 1/1
    • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
    • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
  7. Xiaomi Mi Pad Battery Replacement: 7 단계, 이미지 1/3 Xiaomi Mi Pad Battery Replacement: 7 단계, 이미지 2/3 Xiaomi Mi Pad Battery Replacement: 7 단계, 이미지 3/3
    • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Jessica
회원 가입일: 09/03/15
713 평판
안내서 1개 작성함
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G5
3 회원들
안내서 13개 작성하였습니다
댓글 12개
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - 답글
Go to Leamington road and you will get it
affan -
Go to Leamington road mumbai
affan -
Where to purchase the Mi Paf battery?
Dino Bay - 답글
Please please make a video for it. I need it desperately.
Man Mohan Shukla - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 24
30일 전: 126
전체 시간: 23,545
