주요 콘텐츠로 건너뛰기
Xiaomi Mi Pad Headphone Jack Replacement
필요한 것
  1. Xiaomi Mi Pad Headphone Jack Replacement, Rear Case Assembly: 1 단계, 이미지 1/1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Headphone Jack Replacement: 2 단계, 이미지 1/2 Xiaomi Mi Pad Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 1/2 Xiaomi Mi Pad Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 2/2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
    • Insert the corner of a plastic opening tool into the port of the headphone jack for easier removal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rene Mendoza
회원 가입일: 09/03/15
311 평판
안내서 2개 작성하였습니다
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G5
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
And where to buy? :-(
marcusvoag - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 2,444
