주요 콘텐츠로 건너뛰기
Xiaomi Mi Pad Motherboard Replacement
필요한 것
  1. Xiaomi Mi Pad Motherboard Replacement, Rear Case Assembly: 1 단계, 이미지 1/1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Motherboard Replacement: 2 단계, 이미지 1/2 Xiaomi Mi Pad Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Xiaomi Mi Pad Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the twelve 3 mm Phillips #00 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the two 3.0 mm Phillips #00 screws securing the motherboard to the device.
  6. Xiaomi Mi Pad Motherboard Replacement: 6 단계, 이미지 1/2 Xiaomi Mi Pad Motherboard Replacement: 6 단계, 이미지 2/2
    • Disconnect the six ribbon cables attached to the motherboard using a plastic opening tool.
  7. Xiaomi Mi Pad Motherboard Replacement: 7 단계, 이미지 1/1
    • Carefully remove the motherboard from the device.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Kiefer Sivitz
회원 가입일: 09/03/15
560 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G5
3 회원들
안내서 13개 작성하였습니다
댓글 4개
It's my email
amaank987321.msk@gmail.com
MSK DIGITAL MEDIA - 답글
i'm looking to buy a motherboard for my died mi pad and i couldn't find it any were. Do you know were i can bay one , please help
Vasile Postolache - 답글
I want mi pad mother board
Where I buy
Sunil - 답글
where can i buy matherboard for Xiaomi Mi Pad 4 ?
guyv1975 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 69
전체 시간: 6,768
