주요 콘텐츠로 건너뛰기
Xiaomi Mi Pad Rear Case Assembly Replacement
필요한 것
  1. Xiaomi Mi Pad Rear Case Assembly Replacement, Rear Case Assembly: 1 단계, 이미지 1/1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Case Assembly Replacement: 2 단계, 이미지 1/2 Xiaomi Mi Pad Rear Case Assembly Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kiefer Sivitz
회원 가입일: 09/03/15
560 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-5, Blackwell Fall 2015 USF Tampa, Team 12-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G5
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 16
전체 시간: 1,224
