주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xiaomi Mi Power Bank 10400mAh 수리는 자사의 서비스 설명서를 사용하세요.
  1. Xiaomi Mi Power Bank  10400mAh Teardown, Xiaomi Mi Power Bank  10400mAh Teardown: 1 단계, 이미지 1개 중 1개
    • This is the model
  2. Xiaomi Mi Power Bank  10400mAh Teardown: 2 단계, 이미지 3개 중 1개 Xiaomi Mi Power Bank  10400mAh Teardown: 2 단계, 이미지 3개 중 2개 Xiaomi Mi Power Bank  10400mAh Teardown: 2 단계, 이미지 3개 중 3개
    • Remove it with a knife. Be really careful not to cut yourself
    • The top is attached with double sided tape.
  3. Xiaomi Mi Power Bank  10400mAh Teardown: 3 단계, 이미지 1개 중 1개
    • Remove 4 screws, and push the battery and circuit board out.
    • You need to resolder the battery to the PCB.
    • To keep the battery tight I used a piece of double sided foam tape on on of the edge cells
작성자
4다른 기여자 명과 함께
Martin Hampton
회원 가입일: 02/13/16
1,350 평판
안내서 7개를 작성함
2가이드 댓글
Umm there’s missing steps - the bottom cover also needs removed? How do you push the battery out? Both sides are screwed in please help or finish t his guide thanks
emanoyhl - 답글 공유
Hi emanoyhl, this guide is a teardown and it looks like it is still in progress, so it's not totally complete yet. I did a search and found a guide for a similar device but for the LED however it does show a little more of the internals. Check out the Jerking LED fix in 10000mAh Mi Power Bank 2S, it's not exactly the same device but it seems to have similar construction and you might be able to reach the battery the same way? I hope this helps!
Sarah Westberg - 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 103
전체 시간: 6,828
