주요 콘텐츠로 건너뛰기
Xiaomi Redmi 2 Ambient Light Sensor Replacement
필요한 것
  1. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 9 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 10 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 Ambient Light Sensor Replacement: 10 단계, 이미지 2개 중 2개
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Ambient Light Sensor Replacement, Ambient Light Sensor: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
  13. Xiaomi Redmi 2 Ambient Light Sensor Replacement: 13 단계, 이미지 1개 중 1개
    • Using your fingers, gently pull out the ambient light sensor.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alicia Brenner
회원 가입일: 10/01/15
3,569 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G3
2 회원들
안내서 5개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 5,558
