소개
Use this guide to remove the ambient light sensor in your Xiaomi Redmi 2 for repair or replacement.
필요한 것
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
Using one prong of the tweezers, lift and loosen the edge of the ambient light sensor from the motherboard.
다른 17명이 해당 안내서를 완성하였습니다.
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - 답글
