소개
Use this guide to remove the front speaker in your Xiaomi Redmi 2 for repair or replacement.
부품
지정된 부품이 없습니다.
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 4개
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
Rademi 2 front Speakers problem
Amol Surve - 답글
