소개
Use this guide to remove the front speaker in your Xiaomi Redmi 2 for repair or replacement.
필요한 것
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
Using your fingers, gently lift the front speaker from the screen assembly.
Thanks. I was replacing a friend's digitizer, and in the process, broke the speaker (they come apart very easily). So I decided to replace her broken speaker with mine (we both have a Note 2). Then I broke MINE taking it out. So now I have to order two new speakers. Arggghhh.
Rademi 2 back Spekar
Amol Surve - 답글
Sar rademi 2 front Speakers probably
Amol Surve - 답글
다른 7명이 해당 안내서를 완성하였습니다.
댓글 4개
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
Rademi 2 front Speakers problem
Amol Surve - 답글
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - 답글
