주요 콘텐츠로 건너뛰기
Xiaomi Redmi 2 Motherboard Replacement
필요한 것
  1. Xiaomi Redmi 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    That's unnecessary. The cover itself has a small notch on it to remove it to the left
    Mad Max - 답글
  2. Xiaomi Redmi 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Motherboard Replacement: 6 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement: 6 단계, 이미지 2/2
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Motherboard Replacement: 7 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement: 7 단계, 이미지 2/2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    I broke the connector of this flat cable, which with a replacement part without having to change the entire mother board? Another doubt, this flat cable is responsible for which function in the cell?
    lucaslgf2 - 답글
    pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
    Rodrigo Cunha - 답글
    Thanks Rodrigo, saved me!
    Rodrigo -
  8. Xiaomi Redmi 2 Motherboard Replacement: 8 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Motherboard Replacement: 9 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement: 9 단계, 이미지 2/2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Motherboard Replacement: 10 단계, 이미지 1/2 Xiaomi Redmi 2 Motherboard Replacement: 10 단계, 이미지 2/2
    • Using the tweezers, pull the antenna connector from the motherboard.
    motherboard damage
    Rahul - 답글
  11. Xiaomi Redmi 2 Motherboard Replacement: 11 단계, 이미지 1/1
    • Lift the motherboard out of the front cover and set aside.
결론
다른 46명이 해당 안내서를 완성하였습니다.
Alicia Brenner
회원 가입일: 10/01/15
3,539 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G3
2 회원들
안내서 5개 작성하였습니다
댓글 17개
this is very helpful
Ana - 답글
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
asreefbashak - 답글
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
jhon Carter - 답글
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
Jakka Akhilesh - 답글
how and where to buy motherboard for redmi2
DHANANJAY KALKOTE - 답글
i want new mothe board redmi
ASHOK KUMAR - 답글
i want redmi 2 prime mother board
ASHOK KUMAR - 답글
How to buy redmi prime 2 mother bord
ANYTHING ANYBODY - 답글
hey my Redmi 2 is not working, what can I do? it started to make turn off it self time by time and after it turn off completly, if I make to turn it it on not working, it makes vibration only without turn on, what can I do?? please help me because am just seeking a help
NIYIGENA Moses - 답글
Sir, my phone (Redmi 2 prime) doesn't starts. One day it got off on 0% charge. I put it on charge but from the next day it was not opening. What to do?
Sagarnil Mukherjee - 답글
My phones mother bord is damaged I needed it
mohan gowda - 답글
Rodrigo Cunha - 답글
My phone is mother board damage I need it
Rishikesh Meena - 답글
Hello, i want ask for u, my handpone redmi 2 lte can’t on..why? What is problem?
sazuwan saz - 답글
Great! This phone is very easy to disassembly!
Serg - 답글
السلام عليكم
لدي جوال شاومي s2
منفذالشاحن خربان
Omar Halawane - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 28
전체 시간: 34,997
