주요 콘텐츠로 건너뛰기
Xiaomi Redmi 2 PCB Circuit Board Replacement
필요한 것
  1. Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: 1 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: 1 단계, 이미지 2/2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 PCB Circuit Board Replacement: 2 단계, 이미지 1/1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 PCB Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 PCB Circuit Board Replacement: 4 단계, 이미지 1/1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 PCB Circuit Board Replacement: 5 단계, 이미지 1/1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 PCB Circuit Board Replacement: 6 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 6 단계, 이미지 2/2
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 PCB Circuit Board Replacement: 7 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 7 단계, 이미지 2/2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 PCB Circuit Board Replacement: 8 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 8 단계, 이미지 2/2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 PCB Circuit Board Replacement: 9 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 9 단계, 이미지 2/2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 PCB Circuit Board Replacement: 10 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 10 단계, 이미지 2/2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 PCB Circuit Board Replacement: 11 단계, 이미지 1/1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 PCB Circuit Board Replacement, PCB Circuit Board: 12 단계, 이미지 1/1
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  13. Xiaomi Redmi 2 PCB Circuit Board Replacement: 13 단계, 이미지 1/1
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  14. Xiaomi Redmi 2 PCB Circuit Board Replacement: 14 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 14 단계, 이미지 2/2
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  15. Xiaomi Redmi 2 PCB Circuit Board Replacement: 15 단계, 이미지 1/1
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  16. Xiaomi Redmi 2 PCB Circuit Board Replacement: 16 단계, 이미지 1/2 Xiaomi Redmi 2 PCB Circuit Board Replacement: 16 단계, 이미지 2/2
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Alicia Brenner
회원 가입일: 10/01/15
3,539 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G3
2 회원들
안내서 5개 작성하였습니다
댓글 3개
my phone is head phone signal
Momo Bachaspatimayum - 답글
Battery terminal shouting help
Adil - 답글
I want purches PCB Circuit not available in Akola service center
narendra thokal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 14
전체 시간: 20,792
