주요 콘텐츠로 건너뛰기
Xiaomi Redmi 2 PCB Circuit Board Replacement
필요한 것
  1. Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 PCB Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 PCB Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 PCB Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 PCB Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 PCB Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 PCB Circuit Board Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 7 단계, 이미지 2개 중 2개
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 PCB Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 PCB Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 PCB Circuit Board Replacement: 10 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 10 단계, 이미지 2개 중 2개
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 PCB Circuit Board Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 PCB Circuit Board Replacement, PCB Circuit Board: 12 단계, 이미지 1개 중 1개
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  13. Xiaomi Redmi 2 PCB Circuit Board Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  14. Xiaomi Redmi 2 PCB Circuit Board Replacement: 14 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 14 단계, 이미지 2개 중 2개
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  15. Xiaomi Redmi 2 PCB Circuit Board Replacement: 15 단계, 이미지 1개 중 1개
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  16. Xiaomi Redmi 2 PCB Circuit Board Replacement: 16 단계, 이미지 2개 중 1개 Xiaomi Redmi 2 PCB Circuit Board Replacement: 16 단계, 이미지 2개 중 2개
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alicia Brenner
회원 가입일: 10/01/15
3,569 평판
안내서 5개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2015 USF Tampa, Team 1-3, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G3
2 회원들
안내서 5개를 작성함
3가이드 댓글
my phone is head phone signal
Momo Bachaspatimayum - 답글
Battery terminal shouting help
Adil - 답글
I want purches PCB Circuit not available in Akola service center
narendra thokal - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 21,132
